05-23-2022 07:23
05-23-2022 07:23
As of this morning, Monday, 23 May 2022, there are no core stats visible. I rely on seeing these to check my step number within the hour.
Best Answer05-23-2022 07:46
05-23-2022 07:46
@Marly- I am reading your post differently from @SunsetRunner. To me scrolling down is the same as swiping up and you aren't see your widgets when you swipe up. Restart your Sense by holding the button for 10 seconds or more until you see the Fitbit logo. The Versa 3 has the same operating system as the Sense and this happened to me three or four times. A restart always worked.
Laurie | Maryland
05-23-2022 07:42
05-23-2022 07:42
Hello @Marly-
I hope I understand your question correctly. I think you mean the core stats on your Fitbit tracker:
If you mean on the Fitbit App, then just open the Fitbit App and tap edit at the top right of your page, add what activities you want to be visible then tap done,
😃 I hope that answers your question. Let me know
05-23-2022 07:46
05-23-2022 07:46
Laurie | Maryland
05-23-2022 08:06
05-23-2022 08:06
Thank you! This has worked perfectly. I wanted to try a restart, but couldn't find out how 🤔!
