03-22-2022 02:43 - edited 03-22-2022 02:46
I turned on the snore report and sense microphone last night before bed. I clicked on the sleep tile and then restoration but do not see the report. My battery level dropped from 73 to 54 in 5 hours of sleep. That is a lot more than when snore report was not turned on.
Does it take a while to populate and show up or am I missing something?
03-22-2022 02:53
03-22-2022 02:53
Hi @Clove6060
I'm pretty sure when I tested it out it showed up at the same time as the sleep data. However I quickly turned it off as I didn't think the battery drain was worth it for me, I share a bed so I don't believe there is any way it can determine who the snoring is coming from.
From what you describe the battery drain seems consistent with the feature, so it does sound like it was active. Have you tried syncing a few more times to see if the data appears?
03-22-2022 02:59 - edited 03-22-2022 03:10
Yes I have synced several times, force closed app, restarted sense, restarted phone, but no report.
I am wondering if it takes a while to show up, similar to the SpO2 data. I’ll check it in a hour or so to see if the report appears.
03-23-2022 02:03
03-23-2022 02:03
Snore report showed up for last night.
All good (including the report)!
I plan to run it for a week and see if it consistently records each night or if the recordings are sporadic like another member reported.
Thanks for the help!
03-24-2022 05:47 - edited 03-24-2022 05:47
Second night in a row with report to view.
Another encouraging note is my battery drain
is only 20% from turning in to wake up.
