01-24-2023 00:35
01-24-2023 00:35
Hi there
Recently I bought the Fitbit sense to replace my previous watch.
With the previous one, the notification stays at the watch even if the notification was removed from the phone, which is quite helpful.
Since my phone is Pixel 5, for some applications, only the latest notification will be shown, and the rest of them will be hidden / faded away automatically.
With the experience of the previous watch, I don't have to open the application to check all the previous notifications by my own and all I have to do is just check it on the watch directly.
The issue I have with the Fitbit sense is that since only the latest notification is shown on the phone, the Fitbit sense thought I've read all the previous notifications.
However, the truth is not....
Is there any way I could keep all the notification on the Fibit sens until the limitation of 30 messages is reach?
Thanks!
Best Answer01-24-2023 04:15
01-24-2023 04:15
Hi @Philfeel - the behaviour is the Fitbit App sends any notifications that appear on your phone Status bar [for applications that you select] to the watch [if it is synced properly].
If you remove one from your phone it is removed from the watch [if it is synced properly].
It can be removed from the phone in several ways, by clicking on the Notification on the phone or opening the corresponding phone app or asking the watch to open the app or by clearing it from the watch [if it is synced properly].
Potentially if you turn off Bluetooth any actions on the phone won't be reflected on the watch, but nor will any new Notifications appear.
There can be issues when the watch isn't kept in sync and it's sometimes possible the notifications on the watch will remain or be hard to remove.
