11-28-2020 10:44
11-28-2020 10:44
I am not receiving text notifications and my mindfulness keeps shutting down when I try to open it
Best Answer11-28-2020 11:17
11-28-2020 11:17
Yea the Mindfulness app is a sensitive little bugger, I have found a simple way to fix and that is to log out of the Fitbit app and log back in again, I do notice i need to reset my bluetooth settings when i do thi,s along with reconnecting Google assistant and wrist call... maybe your notifications will work again when you try this
Best Answer11-28-2020 12:06
11-28-2020 12:06
Best Answer11-28-2020 12:25
11-28-2020 12:25
Then there is this
Delete the Eda/Mindfulness App
Log out of the Fit bit app
Force stop the Fit bit App
Restart phone
Reset Watch By Pushing and holding the Left hand button until Logo appears
reload EDA app and log on to the Fit bit app
Good luck
