I called because my Sense wasn’t charging as fast as it used to. The First contact tech I spoke to had me try many things. Finally, he made me go to factory reset! My fault, I should have known better. I did everything he says. An hour and a half, my watch was not working and couldn’t reconnect. Then he tells me I need a new charger!! My watch was fine before I followed the directions of the incompetent tech. I asked to be transferred to the next level tech support. 3 times he put me on hold to see if anyone was available. Of course none were supposedly. I told him now I gave no watch and I’m not getting off the phone until he escalates the call. Got someone who knew her stuff, but couldn’t t correct the damage the first tech did. I get an email offering me a discount to purchase a new device!! What?! Their tech ruined the watch, and their solution is to give me a discount on another one? Unacceptable. I want a Corporate Representative contact me .
Best AnswerHi, @Litrails It's a pity you have had such a difficult experience. I'm not convinced your "Sense" could be irreparably damaged by anything you might have done with a charging cable. Charging issues are well documented in the forum and the effect is your device has not been charged. The usual culprit is a failed pin (one of 4) in the charging cable puck (you will see it is stuck if you look carefully). As you are out of warranty a replacement can be bought from Amazon at a modest cost. You should also clean the back of your "Sense" to ensure good contact, I use rubbing alcohol on a cotton wool swab with a cotton bud to detail the little pits. If your "Sense" is fully discharged it will take about an hour on charge for it to come back to life. If you sync the app on your phone you should see the battery value start to increase slowly. You may be interested in this article Why isn't my Fitbit device's battery charging?
I hope this helps, please let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
Best AnswerHi, @Litrails, have you tried charging the "Sense" with a new cable, give it about 60 minutes. The cost of a cable is very modest compared with the cost of your "Sense".
Tell us how you get on.
Cheers
Gr4ndp4 | UK
