Hi Network
I recently acquired my Fitbit Sense and the first 1 - 1.5 days it worked with no issues. It connected fine with the app - really no problems.
But after the second day and today (third day) I have had nothing but issues, connecting the Fitbit app to the watch. Apparently, it syncs well but I'm unable to add/remove apps, change clock faces etc etc.
Fitbit support tells me that my OnePlus device is not compatible ...
I saw a similar post just for iOS but decided to create a separate post for Android. Has anyone resolved this issue on an Android device?
In advance, thanks.
Best AnswerDo you have an add blocker installed? If so disable or whitelist www.google-analytics.com.
Work out for me
Best AnswerHi Mads
It freaken worked!!!
Thanks a bundle!!!!!!
