01-14-2022
13:45
10:58
EstuardoFitbit
01-14-2022
13:45
10:58
EstuardoFitbit
Hello!
I’m so disappointed with my sense. I’ve been using for 1 week and I’ve noticed that PACE and KM isn’t accurate at all. I used to have charge 3 and the experience was totally different. I want to return the watch back. What can I do?
Best Answer@JulianaDandara If you bought your Sense from Fitbit, you can return it for refund under its Terms of Sale policy. Contact Support for return authorization. If you bought it from a different vendor, refunds depend on that vendor's policy.
Laurie | Maryland
Hello @JulianaDandara
as you wrote both distance and pace are displayed incorrectly. As distance (and therefore pace being just time/distance) is measured via steps multiplied by stride the problem could be in either factors. I tend to believe the stride could have been changed (somehow) when moved from Charge 3 to Sense I would first check it and eventually change it to a proper value.
You can find Stride Lenght in your Fitbit app (on your smartphone), under account (profile icon on top left) -> Activity & Wellness -> Exercise. If it set in automatic try to set a value manually, it might be that the algorithm didn't make a good estimation.
