Poor battery life
I charged my sense yesterday afternoon and already within 24 hours it's at 57%. I have everything turned off and I even turned my Bluetooth off! It's very disappointing. What can I do about this?
6 REPLIES 6
Make sure you don't have score snore detection turned on; that a big battery user.
What is Score detection?
Do you mean "Snore detection"?
Hi @jole1512 -  Yes.
I can get 2 full days with SPO2 on, always on display on, notifications on and around an hour of GPS use.  If I switch always on display off I can push that to 4 days.  My Sense is a year old.
Hi @Anj.P  - just to be sure, you have removed the SpO2 tracker app, have display timeout at 8 seconds, brightness on normal, and don't use an SpO2 clock face or one that uses a lot of battery?
And have restarted the watch with Shutdown from the watch menu, wait 10 seconds and place on the charger to restart it and fully charge it.
Others have reported issues with versions of the firmware, especially more recent than 44.128.5.38.
In light use mode I get nearly 7 days., That's with notifications.
Hey!
I'm not even sure what the spo2 tracker app is 😅 I will have a Google.
Using the Waveform face.. the display is at 8 and brightness on normal too! Will try the reset thing. I don't have my notifications on either!!
