03-04-2022 13:07
03-04-2022 13:07
I found a possible solution to the wrist pressing the button issue I bought screen covers from Amazon for my versus 2 that wrap around the entire watch…top and sides. They also fit the sense. They cover the side button but still allow it to be pressed when needed. It also desensitizes it so bending the wrist doesn’t press it. They come in different colors too. Just a thought…
03-04-2022 17:53
03-04-2022 17:53
i use NAMW TPU screen protectors found on Amazon. I still activate the button every once in a while.
03-05-2022
02:25
07:06
03-05-2022
02:25
07:06
Hi @craftygater - seems like a good idea, presumably it will take some testing to find one which desensitizes it enough for left handed people.
However the one that @Clove6060 suggests installed rotated 90 degrees so button push is not working at all unless the cover is removed partially would work well during exercises.
Or one designed with a special flap.
03-05-2022 06:08
03-05-2022 06:08
03-05-2022 09:55
03-05-2022 09:55
Guy has developed a great watch face that actually rotates the face should you wish to use the Fitbit on your other arm and have the button facing your forearm. It is available in the watch face gallery.
I believe it is the SimpleClockDuo but I may be mistaken. I use the SimpleClockPro and really enjoy it.
