08-10-2021
10:13
17:53
WilsonFitbit
08-10-2021
10:13
17:53
WilsonFitbit
Hi,
I have a question on the accessory straps for the Sense.
The standard short band is just a bit too tight in the largest hole.
However, the long band is too long. I use the 4th hole which leaves a 3" long 'tail'.
Are any of the accessory straps (sport, woven, leather) more appropriately sized?
I'd hate to return it if a solution can be found!
Hello @RussianBlue. Welcome to the community forums. @Odyssey13 Nice to see you around and thanks for your great input.
I'm sorry for the experience you had. At this time, I was able to see that information regarding your question was provided on Odyssey13's post. If it was the answer you were looking for, I'd recommend marking that answer as the best answer. By doing this, other users with a similar inquiry will find a faster response.
See you around.
