10-15-2024 12:52
10-15-2024 12:52
Is it possible to rearrange the order of stats displayed during an exercise? I'm only interested in heartrate and I have to swipe about 10 times to get to it
Best Answer10-16-2024 04:10
10-16-2024 04:10
@eznohstar You can customize your stats screen. If you are only interested in heart rate, this might be exactly what you are looking for. The screen shows a top, middle, and bottom stat in the Exercise app. You can customize each stat, but you must do it in each shortcut your use. An example for running.
The top stat is distance and the bottom stat is elapsed time by default. You can change one of these to Time of Day, if you don't want to see your distance or elapsed time.
Laurie | Maryland
10-16-2024 04:10
Laurie | Maryland
Best Answer10-16-2024 15:41
10-16-2024 15:41
Just what I was looking for, thanks very much!
