03-28-2021 09:36
03-28-2021 09:36
The more I wear my Sense, the more I dislike it (my son says hate is a strong word). The responsiveness of the screen is terrible. I've read a number of posts - some say tap twice, some say tap towards the bottom, one says use a jackhammer... You'd think with a name like Sense it would be 'sensitive'. When I do tap hard enough for however many times, the screen is already 2 or 3 screens past where I want to be. I've talked with customer service and their only solution is to restart the device. Did anyone actually do any physical user testing of the Sense and see how it really worked? It doesn't matter how many features it has if you can't actually get to them. So disappointed.
03-29-2021
17:41
07:34
03-29-2021
17:41
07:34
Welcome to the Fitbit Community, @KAnnM.
I appreciate your participation in the Forums and sharing your experience. I understand how you are feeling and appreciate your feedback as it helps us to keep improving. Thank you for trying to resolve the issue and contacting our Support team regarding this. If you continue experiencing difficulties, please feel free to contact our Support team back as they have already all the details and special tools to continue assisting you.
See you around.
Best Answer03-30-2021 04:25
03-30-2021 04:25
03-30-2021 21:02
03-30-2021 21:02
I couldn’t agree more. The poor responsiveness is so frustrating. I really regret purchasing it at this point.
03-31-2021 10:15
03-31-2021 10:15
Unlike the earlier (Charge, One, Zip, Flex) models, the Sense has a touch screen. Your double tap should really be a double touch, the same type of touch used when typing on the phones screen.
Then Sense is also not very forgiving and if the finger slides while tapping, the touch is detected as a swipe.
Best Answer03-31-2021 11:35
03-31-2021 11:35
Best Answer06-07-2021 19:38
06-07-2021 19:38
Totally agree. It is either hyper sensitive or non responsive
Best Answer06-07-2021 20:00
06-07-2021 20:00
Don't tap at all is the solution no need as you simple press the side button taping the watch is horrendous and more likely to cause harm to the watch by the time you tap it twice you could have pushed the side button thrice sorry couldn't help myself. so plainly put use the side button for waking your watch I have mine set to motion and button to do so taping the watch is reserved for short cuts in my opinion. if you choose to ignore my advice about the tapping you will stay frustrated forever about it simple push the button.
Best Answer06-08-2021 04:39
06-08-2021 04:39
06-08-2021 07:02
06-08-2021 07:02
It is indeed frustrating. It only works a few seconds after the screen has been awakened by either wirst motion or pressing the button. However if it's "asleep" the tap to wake feature hardly works - sometimes requiring 6-7 hard taps before it comes on.
Was hoping this would have been fixed in latest software update but it has not. It's a feature that does not work as intended and clearly not an isolated issue if you look through the forums.
Agreed also that reaching across to press the button is hardly ideal, especially when excercising. Hopefully this gets fixed, some day.
06-08-2021 09:03
06-08-2021 09:03
Don’t know if Fitbit is acknowledging this as an issue but this my second sense and I think I will take it back to bestbuy. Not sure if I will try and replace it with a third sense or just give up.
Best Answer06-08-2021 09:57
06-08-2021 09:57
I found a special trick to make double tap working, at least it works 9 out of 10 for me. The taps must be reasonable firm and on second tap keep the finger on the screen, dont lift it
06-08-2021 10:38
06-08-2021 10:38
Tried this suggestion but still does not work for me. I find if I double tap the bottom of the watch (not the screen but the bottom area where the metal wraps around the face) it tends to work better.
