09-27-2020 16:45
09-27-2020 16:45
Hey guys. I received my new fitbit last Thursday and I'm so excited to use since this is my new fitbit ever.
prior to that. I have been shopping for screen protectors online and I have seen way too much options.
I probably spent almost $40 on screen protectors. From the ones that you have to squeeze in like a cover, peel and sticks and a weird way of applying a protector with water.
I just want to share my experience on all of them since well know how much we have all spent for the fitbit sense. the cover in which you have to press through the screen are cool but it accumulated way too much moisture and made the watch so bulky. it would've been awesome if it was thinner. the peel and sticks are a waste of money. then there was this product called Ace Armor. i got it from amazon for $9. though the installation is weird I highly recommend their brand. I have included the link since I know that this is a must have accessory for our new fitbits.
You're welcome guys this is the only product that works best.
09-27-2020 19:36
09-27-2020 19:36
I just ordered a screen protector from Amazon. Its the thin shield that is applied using the "wet" method. I've used it before for my Versa and it worked great. So easy to install no bubbles and holds up well. I will say even though it states you can swim with it I don't. I don't shower with my Fitbit on either so I can't speak to how it holds up to those activities.
09-27-2020 18:43
09-27-2020 18:43
Has anyone else had good luck with any screen protector?
09-27-2020 19:32
09-27-2020 19:32
I just got this from AliExpress.....here's the link:https://www.aliexpress.com/item/1005001473059321.html?spm=a2g0s.9042311.0.0.3d2e4c4d1eeTpn
09-27-2020 19:36
09-27-2020 19:36
09-28-2020 14:23
09-28-2020 14:23
For me this brand is the only one that worked for me so far. its the wet installation. comes with 6.
09-28-2020 14:24
09-28-2020 14:24
I had bad experience with ali express. it took 3 weeks to get a merchandise and they gave me am item that never fit the description.
09-28-2020 14:26
09-28-2020 14:26
The one I got is the wet installation. I ordered one for my son's fitbit alta 2 also. perfect fit and i think this company claims its waterproof. My son was at the pool all day the other day. screen protection is still intact.
09-28-2020 17:57
09-28-2020 17:57
I used the "Liuipel liquid screen protector for glass screen smart watches". First time I've used it so no idea how well it will work long term but it sure was nice not to have to worry about bubbles.
