You have to go to the 'notifications' section.
Open the app
Tap on your avatar in the top left corner
Tap on the picture of your sense (under devices).
Scroll down and select 'notifications'
Select text notifications and select the app you use for texting.
Lower in the notification screen there are also options for voice reply and quick replies that you can activate.
Hope this helps
-spg
