06-14-2022 11:35
06-14-2022 11:35
My Fitbit sense screen came out. Whether anyone know how to fix this.
06-15-2022 01:15
06-15-2022 01:15
There are a number of posts from people with the same problem. It seems that there is not an easy fix for this but if you are still covered by the warranty then you should be eligible for a replacement. I suggest contacting customer support via contact.fitbit.com who can check your warranty status and advise on your options.
06-15-2022 01:15
06-15-2022 01:15
