08-13-2022 14:44
08-13-2022 14:44
I have only had my Sense a couple of months. I tried to charge it and the screen went black. I can't feel a button at the side to reboot it. Before it died it showed an update available message. I have charged it for 3 hours and screen is still black. Not had this with any of my previous fitbits
08-13-2022 20:03
08-13-2022 20:03
Connect your Sense to the charger - try to hold the button for at least 10 seconds and the Fitbit Logo should appear.
08-13-2022 20:34
08-13-2022 20:34
Hi @SG47 - it sounds like it is not charging, quite a common issue, see this link for cleaning and diagnosing instructions How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
08-14-2022 00:27
08-14-2022 00:27
Thank you Guy so much for your help. Fitbit are sending a new charger !
08-14-2022 00:40
08-14-2022 00:40
Thanks for your help !
