08-24-2023 04:42
08-24-2023 04:42
Sense I received from Iconic recall has started to fail. Is this a common occurrence. Only one clock face, an SPO focused face works properly. Nothing else seems to perform.
Best Answer08-24-2023 06:28
08-24-2023 06:28
Hi @SunsetRunner - if could be a clock face issue and loading another Fitbit clock face should work.
Swiping to Settings should also work correctly, if it doesn't you may need to do a factory reset but if the hardware is beginning to fail it mail not fix it.
