03-30-2021
17:01
07:32
03-30-2021
17:01
07:32
I performed a soft reset on my Fitbit Sense when menu items were greyed out and not displaying properly. After holding down the side button several seconds until it restart, the Fitbit continued to keep resetting every minute or so. The logo will appear for a bit, disappear, then start all over again repeatedly. This has been going on all day now and the device is completely unusable now. I've attempted resetting the Fitbit the same way several times, but it keeps doing the same thing. How do I resolve this issue?
10-04-2022
10:15
10:04
10-04-2022
10:15
10:04
Thank you for sharing your experience and troubleshooting. If your Sense display is experiencing issues, let’s try restarting it by doing the following:
If the issue persists, please get in touch with our Support team.
Best Answer03-30-2021 22:14
03-30-2021 22:14
Same thing happened when I shut mine off, if it's under warranty they should replace it, too bad this seems like a common issue with this device.
04-02-2021 07:00
04-02-2021 07:00
Hi there, @SirJimmyP. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Sense.
According to the description of your post, it seems like you've performed a factory reset instead of a regular restart. That would explain why you cannot connect your watch to your Fitbit app. With that said, I'd recommend trying the steps below:
1. Remove the Sense from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Sense.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Sense.
As for the settings you're seeing grey out on your watch, it seems your Sense was into either Sleep Mode. When the sleep mode setting is on:
To turn off Sleep Mode, please swipe right from the clock face on your watch to access the quick settings. For more information, see How do I navigate my Fitbit device?
Hi there, @Sknightsense. Welcome on board. I understand how you must be feeling. I've seen our Support Team was able to help you after you posted here. 🙂 If you have any questions regarding the outcome of your case, feel free to let our team know about that so they can further assist you.
Have a nice day.
Best Answer04-08-2021 08:13
04-08-2021 08:13
Unfortunately, whether I hard reset the Fitbit or not is unknown. The problem still remains to be that the device would repeatedly restart without getting past the logo screen. Now the device will not turn on at all, and that is after I left it plugged in to charge all night.
04-08-2021 09:52
04-08-2021 09:52
Finally got it.
I had to perform a factory reset on the Fitbit device and it worked again.
04-08-2021 14:23
04-08-2021 14:23
@SirJimmyP I'm glad to hear you managed to solve the issue with your Sense. Thanks for sharing the outcome! 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
Best Answer09-06-2021 10:52
09-06-2021 10:52
Hello, please can you tell me how have you solved you problem. I have the same.. I see only logo and watches doesnt react to anything. Thank you Milan
09-06-2021 11:39
09-06-2021 11:39
Hi there, @Darkanubis007. Thanks for stopping by in the Community Forums.
If you haven't done so yet, please follow the steps below:
If you can't get started with your Sense, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Hope that helps.
Best Answer09-14-2021 12:43
09-14-2021 12:43
I am having the exact problem, numerous restarts, now just the logo screen and nothing else. I've done all the above and nothing.
09-14-2021 13:57
09-14-2021 13:57
@ldzierba I appreciate you had followed the tips and recommendations provided above.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer09-21-2021 12:53
09-21-2021 12:53
How did you do the factory reset? I face the issue
12-18-2021 13:11
12-18-2021 13:11
How did you do it if you can’t get past the logo screen? My friend has the same issue.
12-18-2021 13:15
12-18-2021 13:15
Ya, don’t do this. Customer support is less than helpful.
01-22-2022 12:48
01-22-2022 12:48
I have followed all the steps and my Fitbit is still stuck on the logo screen. It is under a year old. How do we get a replacement? This is obviously the only option I have left
03-05-2022 02:12
03-05-2022 02:12
I've only had my watch a week and it's stuck resetting itself. I hesitated buying this watch. I want me money back if it has to be replaced. This sucks!
03-07-2022 22:34
03-07-2022 22:34
How does a factory reset possible when the watch is stuck at logo screen. It happened to me just now and multiple soft resets and following community moderator's instructions did not work. It is still stuck at logo.
Just one year back I bought it and looks like it's dead...😢
03-14-2022 15:41
03-14-2022 15:41
You should tell her to try to change her Fitbit clock face before unpairing her Fitbit sense. I did you'r instructions first before trying to change my clock face. Now my Fitbit sense is unpared and I'm unable to try it.
It's been stuck on the logo screen since February. I've had it constantly on the charger. Trying to restart it by the button.
03-14-2022 16:36
03-14-2022 16:36
@DJ_BikeWala Just seeing this. It would've been quicker to Google search.
Hold the back button for about 8 seconds.
When the Fitbit logo disappears:
Release the button briefly (for less than 2 seconds).
Hold the button again until you feel a second, longer vibration, which indicates you initiated the factory reset.
03-15-2022 13:38
03-15-2022 13:38
I have done all this and still have the logo issue.
03-17-2022 19:59
03-17-2022 19:59
Same here, nothing I do will get it off the logo screen I have seen numerous posts about this and no real fix. Mine is not even a year old yet.
Does anyone have a fix for this?
