03-30-2021
17:01
07:32
03-30-2021
17:01
07:32
I performed a soft reset on my Fitbit Sense when menu items were greyed out and not displaying properly. After holding down the side button several seconds until it restart, the Fitbit continued to keep resetting every minute or so. The logo will appear for a bit, disappear, then start all over again repeatedly. This has been going on all day now and the device is completely unusable now. I've attempted resetting the Fitbit the same way several times, but it keeps doing the same thing. How do I resolve this issue?
03-17-2022 20:00
03-17-2022 20:00
Does not work for me, a continuous logo screen no matter what I do. I have tried multiple times and it never goes past the logo screen.
03-18-2022 07:44
04-03-2022 09:57
04-03-2022 09:57
It didn't work for mine but maybe it will for you. I'll keep trying.
04-08-2022 20:26
04-08-2022 20:26
Third time having major days long issue with my Sense. Very very fed up.
The current issue is the frozen logo screen. Tried doing the reset (many many times) but it didn't work.
Do I send it in somewhere for repair or just trash it and get an Apple?
04-09-2022 04:29
04-09-2022 04:29
If you're still covered under the 1 year US warranty. Or the 2 year Europe warranty. Then contact Fitbit Support for a replacement.
I received mine 2 Christmases ago and didn't get the extra 1 year US warranty and I had to go back to my previous Fitbit because my warranty had expired.
The Fitbit Sense is the only Fitbit, I've ever had a problem with.
Maybe in the future they'll Recall or maybe they'll just kick us in the shins for a faulty Smartwatch lineup.
My first ever Smartwatch is now useless to me. 😪
04-09-2022 04:41
04-09-2022 04:41
I sent mine back. Only had it 10 days. Of the 10 I only got to wear it 4 days. Customer service was easy despite some of the reviews i read. They refunded me. I really wanted my watch but happy i was able to get my money back with no problems. I'm back to using my charge 3. I'm not sure if I'll be purchasing anything else. Very skeptical at this point.
04-09-2022
15:28
12:00
DavideFitbit
04-09-2022
15:28
12:00
DavideFitbit
Hi there, I did this and it didnt work, now I cant reconnect it. The watch is off and every minute of so vibrates and shows the logo and that it. I have tried reseting 30 times. This is the 4th time this has happened in 4 months. How do I send it back Im going to apple
Hi there, I have had my sense for 4 months and have to reset it monthly. Now its just in a loop, vibrates, logo appears and repeat.
I have tried a reset, a factory reset. I am sooo over it. Support is below average and now I just want it gone and I will go to apple.
04-09-2022 16:39
04-09-2022 16:39
https://myhelp.fitbit.com/s/support
Tap on live support and let them know what you want to do.
I wish I had that option but my warranty has expired.
This is obviously the device and not us.
04-09-2022 16:54
04-09-2022 16:54
04-09-2022 19:16
04-09-2022 19:16
Looks like trash it is.
Which while unfortunate is better than relying on unreliable hardware.
#caveatemptor
06-07-2022 16:21
06-07-2022 16:21
I messaged the chat team and said I have a major issue: my fitbit has been stuck on the logo for the past week or two. I also mentioned a minor issue: a scratched screen. In retrospect, I probably shouldn't have mentioned the cosmetic issue, because they suggested I buy a new Sense for 35% off because scratched hardware isn't covered by their limited warranty (I also told them I have the 2-year extended warranty).
I find it ridiculous since this device is less than a year old (ordered in October, so ~7 months!), the charging pins on the charger and the charging connections on the Sense are both a bit corroded (I have tried to keep them clean, but keeps coming back), and it's also stuck on the logo... so why would I want to buy a new one if it's barely going to last a half year?
I had to email them back and reiterate that I got the 2-year Allstate warranty, so now they want me to file a claim through their external insurance. It also feels ridiculous that I need to file a claim when this very much feels like a production issue. I'll likely never buy a fitbit product again. 😞
06-07-2022 17:38
06-07-2022 17:38
That's weird. They didn't ask you if you wanted a replacement?
You have the 2 year warranty and it's even under 1 year.
Please go back to support and straight up ask them for a replacement.
Just tell them your Fitbit Sense is stuck on the Logo and you need a replacement.
I wish I was in you'r position. I received mine 2 Christmases ago and didn't get a 2 year warranty. This past February mine got stuck on the Logo and that was it. Now I'm using my old Fitbit Charge 3.
07-09-2022 20:01
07-09-2022 20:01
I can't re connect the device in your steps because it's still stuck on the logo. I've tried restarting it's just not doing much. I didn't even initiate this it was just stick this way when I tried to see the time. The restart step just b brings out back to logo .
07-09-2022 21:08
07-09-2022 21:08
Hi @SunsetRunner , @Champ7777 - did you try this cure Stuck on logo , it may work for you or others.
07-09-2022 21:27
07-09-2022 21:27
Thanks Guy, I'll give the hour charge a try in the morning. It didn't respond when I put it on there, but I didn't wait long. I'm also hopefull that if your charge idea doesn't do it maybe letting it die will.
07-09-2022 21:36
07-09-2022 21:36
@SunsetRunner - thanks, if it doesn't respond to charging the battery is most likely already flat, in which case see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
07-10-2022 09:39 - edited 07-10-2022 16:49
Update: it has randomly woken up and is back to being stuck on the logo screen.
Previous: I let it die overnight (the screen had enough battery to sat "0%") then I plugged it in to charge. It behaved a little differently but went right back to the restart/ frozen logo cycle. I left it for an hour and now its just dead completely. no screen no lights. Just a lame-o paperweight. Fitbit support basically said clean it, charge it and get back to us (which I've already done, so I don't have high hopes.)
Thanks for the idea though.
07-15-2022 00:40
07-15-2022 00:40
Did we get this problem fix mine just started to do this just about had it 8 months
07-15-2022
00:51
07:20
07-15-2022
00:51
07:20
Hi @Strawberry1988 - did you follow the advice given here by @MarreFitbit
If that doesn't work you can chat via the Fitbit App,click profile photo, Help & Support, Contact Customer support, they may take you through a factory reset and setup again.
As it's under warranty you can take it back to where you bought it for a replacement new one if you can't get it working.
07-26-2022 13:49
07-26-2022 13:49
How can you perform a factory reset when the screen is stuck on the logo screen.
