04-07-2021 17:27
04-07-2021 17:27
Under my Bluetooth settings on my IPhone it lists Sence Controls but I can’t get it to connect. It keeps saying to make sur Sense Controls is turned on and in range and it is. Anyone else have this problem? I’m new to this tracker. Thanks,
04-08-2021 11:26
04-08-2021 11:26
Hi, for your info, Sense Controls only connects when you receive or make calls. Under normal operation, Sense Controls is disconnected. Hope this helps
04-08-2021 04:00
04-08-2021 04:00
I'm was having this problem a lot. One thing that I figured out is that you should only use the clock faces made by fitbit. Which is annoying because that eliminates all the fun ones. Once I changed back to a fitbit clock. I deleted the watch and reinstalled it. This worked!
04-08-2021 07:23
04-08-2021 07:23
04-08-2021 11:26
04-08-2021 11:26
04-08-2021 11:29
04-08-2021 11:29
