05-25-2022 05:09
05-25-2022 05:09
My Fitbit Sense is not showing any alphanumeric data. Only graphics are showing. I tried doing a reset by holding the button down 10 seconds several times and changing the watch face. Problem started after charging.
Best Answer05-25-2022 05:16
05-25-2022 05:16
Is this only on the clock face, or on any screen?
Are these third-party clock faces, or "by Fitbit"?
Best Answer05-25-2022 06:40
05-25-2022 06:40
On all screens regardless of clock face author. I only use Fitbit clock faces.
Best Answer05-25-2022 07:18
05-25-2022 07:18
@AaronM1978 wrote:On all screens regardless of clock face author. I only use Fitbit clock faces.
In that case, I'm no help. Sorry.
Best Answer05-25-2022 09:06
05-25-2022 09:06
My only thought would be to try a restart, by holding in the button.
Or a shutdown through the settings on the Sense. Then to turn on, hold the buttin in or place the Sense on its. Powered charger
05-25-2022 10:12
05-25-2022 10:12
Anything that involves alphanumeric information is not functional. I can get to the settings menu by clicking on the gear icon, but no text is displayed in the menus.
Best Answer05-25-2022 10:26
05-25-2022 10:26
A restart did not help.
The shut down command is at the very botton on the settings page..
I might suggest trying to setup the Sense, without first removing the Sense, as a replacement device. If the setup fails, your Sense will not be removed.
However you may want to contact support.
