Hi. I have had many fitbits with silicone bands since 2014. For some reason the Sense silicone feels different and has actually burned my skin several times. What makes this one so different?
It happened to me once after a lot of repetitive movement.
There may have been dust or moisture between the skin and band, and wearing it loosely or too tight can cause a lot of friction [because of the size/weight of it] if you are doing frequent movements.
It's important to keep it clean.
You can get alternative type bands.
