07-04-2022 10:33
07-04-2022 10:33
If your WIFI is enabled for 2.4 and 5 ghz under the same SSID, your Sense will have trouble connecting. Period.
Create another SSID with 2.4 only.
Best Answer07-04-2022 17:22
07-04-2022 17:22
That is true, fitbit will try to connect to the SSID the user setup, if both are the same, the sense will try and connect to the first one detected.
However most routers have different SSIDs for the two.
