12-24-2021 11:59
12-24-2021 11:59
I have a Versa 3 and a charge 2. I was thinking of replacing the Charge 2 with a Sense.
Will the fitbit app allow this? I have no problems with the Versa 3 and Charge 2 working together.
Best Answer12-24-2021 12:56
12-24-2021 12:56
Sense and Versa 3 will not work together on same account. It works for you now only because the Charge 2 is an older model with different setup.
From Can I use more than one Fitbit device with the same account?
12-24-2021 12:56
12-24-2021 12:56
12-24-2021 14:03
12-24-2021 14:03
Thank you.
Best Answer12-26-2021 22:10
12-26-2021 22:10
Keep your Versa, and definitely skip the Sense. I got the just ‘reboot and wear for three night’ run around for 4 months because it wouldn’t log sleep the way advertised (reason I upgraded from Versa) - finally they sent me new unit, now not only does it mess sleep, it can’t do skin temperature. Miss my Versa - the Sense can’t sense much consistently.
