11-24-2024
08:03
11:44
ManuFitbit
11-24-2024
08:03
11:44
ManuFitbit
Yesterday my battery was at 45% before I shutdown. This morning it was at 0. Is there a way to shutdown completely?
Moderator edit: clarified subject.
Best Answer11-27-2024 12:05
11-27-2024 12:05
@eznohstar- I did some checking for you with my watch and normal battery loss for a Sense when shutdown is about 1% per day, or less ,because starting it each day to check uses some extra battery. If yours is more than that there would seem to be a problem.
Best Answer11-25-2024 07:18
11-25-2024 07:18
@eznohstar- make sure you read the battery level from the watch - swipe the face right to get to Quick Settings to check the level [or even charge it briefly to get the actual level] then do another Shutdown from the Settings menu.
Some watches retain the time even though they are shutdown, so some current is used but if the watch had a fault, like short battery life [after getting wet perhaps] there can be an internal short that continues to drain the battery.
Best Answer11-26-2024 11:39 - edited 11-26-2024 11:41
Hi @eznohstar. Welcome back to the forums.
Thank you for sharing the inquiry regarding your Sense.
Sorry to know this difficulty with your device.
Please take a look at the following help article: Can I extend my Fitbit device's battery life?
Confirm that your device is using the latest firmware version: How do I update my Fitbit device?
Thanks for helping @Guy_
Best Answer11-26-2024 21:49
11-26-2024 21:49
Interestingly it seems to last much longer if I don't shut it down.
11-27-2024 12:05
