12-03-2022
00:23
03:48
12-03-2022
00:23
03:48
Got my new sense yesterday. completed setup after charged 100% last night.
battery ended 0% this morning after 1 night. now sense show blank screen even connected to charger. sense shows light at back and button seems working. BUT screen stays black. Tried the reset. But still black screen.
please advise. thanks
Best Answer12-03-2022 00:32
12-03-2022 00:32
Hi @SunsetRunner - it may need replacing under warranty where you bought it.
Yon can always chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
12-03-2022 03:50 - edited 07-09-2024 07:46
Hi there, @SunsetRunner. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Sense. @Guy_ Thank you so much for your advice!
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
See you around.
12-21-2022 23:21
12-21-2022 23:21
i received my Sense replacement. i have used it for some days by now. i realised that my heart rate readings are much lower compared to my previous Versa. the readings are so low such that my zone minutes are very low. the zone minutes are like 1 zone minute for 31 min workout or 6 zone minutes for 2 hours of hike.
is there an issue for my new Sense? how to verify if the readings are accurate?
Best Answer12-21-2022 23:28
12-21-2022 23:28
@SunsetRunner - have a look in the forums concerning heart rate, some report it under reads while others report it over reads during movement compared to prior models.
Short of using dedicated measuring equipment you won't know and even then it can vary depending on the movement.
The good news is that at rest it is fairly accurate and so can measure sleep and resting heart rate reasonably well.
Best Answer12-21-2022 23:39
12-21-2022 23:39
@Guy_ @thanks for your reply.
my resting heart rate is also lower using Sense as compared to my previous Versa. which is telling the truth? Should i be really concerned?
23:51
07:46
12-21-2022
23:51
07:46
@SunsetRunner- difficult to know absolute values without another means of measuring. These devices may have a certain degree of variance depending on the device, the user, the activities and conditions.
What is of more value is following trends using the same device, this will give you a fairly good idea of how things are going. If there is a considerable change there may be cause for further investigation, unless the reasons are obvious [such as too much over eating and drinking at Christmas!! lol]
