08-01-2021
09:24
12:33
WilsonFitbit
08-01-2021
09:24
12:33
WilsonFitbit
bough a Sense 3 months ago, and suddenly, the battery died (I had charged it the day before). I charged it again, It took 2 hours, and at 100% charge, it last only 12 hours
Moderator edit: subject for clarity/format
turn off bluetooth.
Check which version of the Fitbit App you have.
There was an issue with it causing high battery drain which was supposed to have been resolved in the latest version, but may have come back.
As @lablover55 says a temporary solution to verify this is to turn off Bluetooth to see if the battery drain returns to normal.
@KennyFoHere's where you can check your watch version. No mention of 44.128.5.49, is this some beta version?
More importantly check you Fitbit App version; profile photo, Help & Support, is it the latest?
@kobrIts only necessary to turn off Bluetooth to isolate if it is a Fitbit App issue. Did you check the version you have?
Best AnswerThanks for getting back to me.
I checked the fitbit app on my iphone > pressed the sense watch icon > there it says last synced, version 128.5.49 & battery low
Probably best to contact Fitbit Support directly to enable them to check this out. They may be able to help you resolve it..
Best AnswerHaving the exact same issue. The battery of my Sense goes from 100% to 14% in 24h. No GPS usage, turned notifications, etc.
Sense Firmware version: 44.28.5.38
Fitbit app version: 3.44 (last updated 2021/07/21)
@ithurtstom Thanks for the feedback - It is interesting to know the bug exists with those versions.
At this point its probably best to inform Fitbit Support directly. They may be able to help you and establish that this is a new issue with 3.44.
Just turn it on when you need to sync. It will resolve itself. Mine did..
