04-21-2024
14:31
08:32
04-21-2024
14:31
08:32
using my sense for a bit more than two years and now battery does not last for a 30 min run. Is anybody facing the same experience?
Hi @Dim_789 - for a battery life that short even with GPS enabled there may be a watch fault.
Also be careful if the watch consumes a full charge in 30 minutes there is a risk of it getting hot and burning you.
Check when charging it doesn't get hot and if so stop immediately.
Hi there, @Dim_789. Welcome to the Fitbit Community Forums. I'm sorry to hear that the battery of your Sense is draining quickly. I understand where your concern is coming from. We're here to help you! @Guy_ I appreciate your input!
I've seen you contacted our Support Team after posting here and they've already assisted you. If the steps that our team has provided did not work, please feel free to contact them back for further assistance. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly. Thanks in advance!
