07-26-2021
06:39
20:20
LizzyFitbit
07-26-2021
06:39
20:20
LizzyFitbit
My sense battery is draining in 2-3 days. I recently bought a sense and its battery is draining too quickly
07-26-2021 07:41
07-26-2021 07:41
Do a factory reset, after setting things up again, turn off bluetooth. See if that helps with battery life..
07-27-2021 20:23
07-27-2021 20:23
Welcome, @Archit23. It's good to see a new face around. @lablover55 Thanks for stopping by to help our members.
Thanks for bringing this to our attention. Before anything else, let me explain that the battery life of your Sense will depend on how frequent certain features such as GPS connection, SpO2 tracking or Always-On Display are used. This doesn't mean that you shouldn't use them, but just to take them into consideration.
That being said and to work on this situation, I'd suggest trying the tips described in this help article to maximize the battery life, fully charge your Sense with the charging cable that came in the box and monitor its behavior in the next days to see how it goes.
Hope this helps.
