07-19-2021
20:05
17:41
LizzyFitbit
07-19-2021
20:05
17:41
LizzyFitbit
I just bought the Sense. The watch won't stay connected to my wifi. At times says the password is wrong even though it is right. I've factory reset the watch which then connected for about a minute and then disconnected again. The watch and phone are paired but not connected. Everything works on the watch but the heart rate won't transfer to my Fiton app which was the goal of all of this.
07-21-2021 18:11 - edited 07-21-2021 18:15
@TaiaP Welcome to the Community Forums.
Thanks for taking the time to troubleshoot your Sense and for the details provided. I'm sorry you're having this experience and to work on this, may I know the model of your phone? Do you have your watch plugged into the charging cable when trying to connect to Wi-Fi? Also, did you see an error message when trying to sync or connect to your Wi-Fi?
If you haven't done so, I'd recommend reconnecting your watch to your account:
About your other question, I went ahead to review your details and it seems you already got in touch with our Support team. Because they're providing you with assistance, please follow their instructions and keep the communication with them.
Hope this helps.
07-23-2021 06:51
07-23-2021 06:51
07-27-2021
19:43
09:10
07-27-2021
19:43
09:10
Hi @TaiaP. It's good to see you here again.
Thanks for getting back with more details, and for your efforts while working on this matter. Before anything else, let me explain that it's not necessary to manually pair your watch in the Bluetooth settings as this process will be done when syncing. The same with the Sense Controls which will connect as soon as you receive a call. If you see them disconnected the rest of the time, that'll be okay as it's the expected behavior.
That being said, it's kind of odd that your Sense appears as M104ZZ4 in the Bluetooth settings. If possible, could you take a picture of that screen and attach it in your reply? This will help me to investigate on my end. Additionally, please skip the first step and give a try to the rest of the suggestions shared above to see how it goes.
In regards to your other question, let me explain that your Sense needs to be plugged into the charging cable in order to connect to your Wi-Fi network. I understand that you'd like to use FitOn and let me share that according to their website, you'll only need to open the FitOn watch app on your Sense before starting a workout to stream real-time heart rate. If this isn't happening, my best recommendation is to get in touch with them so you can receive further details.
