05-03-2021
14:44
10:11
WilsonFitbit
05-03-2021
14:44
10:11
WilsonFitbit
The last few days my sense battery is not even lasting a full day.. it used to last 2-3 days.. I did not change anything .. why is this happening.. it’s no good to
me like this.. only 5 months old
05-03-2021 14:50
05-03-2021 14:50
The same happened to me, mine’s less than 3 month’s old. Contacted Fitbit support, they’re sending me a replacement.
05-08-2021 10:16
05-08-2021 10:16
Hello @heleneire, @SharonBPM. Welcome to the community forums. @SharonBPM Thanks for your great input and I'm happy to hear that a replacement is being sent to you.
@heleneire I'm sorry for the experience and thanks for taking the time to report this matter. I was able to see that you were able to reach out to our Support Team and they have provided information and assistance. Since you have received assistance from them, I recommend updating your case if you still have additional questions or inquiries, this way they can continue assisting you and working on your case.
@SharonBPM I hope to have you back on track soon.
See you around.
Best Answer05-08-2021 19:44
05-08-2021 19:44
Mine is now lasting only 12-14 hours
Best Answer05-09-2021 00:21
05-09-2021 00:21
Mine is the same - less than 5 months old and since I’ve updated it this week, it now drains to 0% within 24 days. I’ll contact customer support too 😞
Best Answer05-09-2021 01:15
05-09-2021 01:15
I had the same problems, battery drain, not syncing and unable to connect to wifi. I then installed the latest ios update (14.5.1) and the firmware of the watch (128.4.17) via bluetooth. That solved the problem for me. Hope this is of any help for you.
05-09-2021 10:57
05-09-2021 10:57
I am having the same issue. Battery drains in less then 24hrs.
Could someone help me with this?
Looks like a lot of folks are having the same issue.
SM
Best Answer05-09-2021 11:04
05-09-2021 11:04
It’s since I updated the app on my iPhone a few days ago. Today it drained down to 0% by 7pm. This is really frustrating 😞
Best Answer05-09-2021 11:28
05-09-2021 11:28
Best Answer05-09-2021 14:17
05-09-2021 14:17
Same happened to me. I did a factory reset, and as of now (a few days now, almost a week), it seems to have fixed the issue. I held off on doing the factory reset, thinking it would be a huge headache, but it was actually quick and easy. Even my non-Fitbit watch face was easy to reinstall. It's worth a try at least.
05-09-2021 17:32
05-09-2021 17:32
Hi JCBish, it takes how many hours for you to full charge the watch and last how many days after the factory reset?
The past 2 days, my one month old Fitbit Sense takes less than 30 mins for full charge, and drain off after couple of hours. It was working fine previously, which was lasting 4-5 days. I just did the factory reset, hope the issue could be solved 😥
Best Answer05-10-2021 03:07
05-10-2021 03:07
The factory reset seems really resolved the battery issue for me. I've reset and full charged it this morning, and after wearing for 9 hours, the battery level is 96% now. I will monitor for couple of days to make sure the issue has really get resolved. Thanks JCBish.
Best Answer05-11-2021 12:01
05-11-2021 12:01
Best Answer05-11-2021 12:02
05-11-2021 12:02
I did the factory reset too and it seemed fine but after 24 hours it started draining 10% per hour and I have now sent it back to Fitbit
Best Answer05-11-2021 12:03
05-11-2021 12:03
I did the factory reset too and it seemed fine but after 24 hours it started draining 10% per hour again and I have now sent my Sense back to Fitbit
Best Answer05-11-2021 22:18
05-11-2021 22:18
Mine is less then a month old and doing the same thing!!
Best Answer05-12-2021 08:09
05-12-2021 08:09
