06-08-2022
04:40
18:01
LizzyFitbit
06-08-2022
04:40
18:01
LizzyFitbit
How long Battery last if day1 morning full charge? Power Input usb but what about amp control voltage amp andall...??
09:21
10:44
06-08-2022
09:21
10:44
Hi @Dgflame - your battery can last anything upto 6 days but if you use a lot of features it can be a lot less, snore detection and the SpO2 tracker app can consume upto 4 of those 6 days.
As regards charging it needs a good 5v usb supply and consumes around 300 ma, except when WiFi is on and can use 340 ma for a brief moment.
A pc usb can be a good source.
Best Answer06-12-2022 04:17
06-12-2022 04:17
thanks for your reply, I have found that my Fitbit sense battery works max for only 2 days only I have doubts about my battery is it in good condition or defective?
04:27
10:44
06-12-2022
04:27
10:44
@Dgflame - it is most likely only a usage issue. I have an original Sense from 2020 and the battery is fine with the proper settings and charging once every 5 days.
Better to check which features or settings need adjusting if you want charge less often. See How to resolve the Major issues causing short battery life
