So left my sense charger plugged in big mistake it attached itself to a torch I had on my bedside nearly caused a fire thankfully I was awake and smelt the burning. Has melted the whole charger??? How can this be safe like magnets in a charger really doesn't seem smart right now.
Hi @Badkarma666 - that's unfortunate - see Tips when using the Sense or Versa 3 charging cable
Probably best to contact Fitbit Support directly. Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
They may be able to help you with a replacement cable if it's covered under warranty or you can get them online.
@Badkarma666 Magnets in chargers are pretty common now as it makes for a better placement, for example Apple and MagSafe.
A torch at bedside (Is this an actual flame?) is probably the real safety question.
