My new Sense came with a USB cable to charge it.
My MacBook Air no longer has any USB ports, what is a safe charging option?
What is a UL certified charger? Is there a Australian version?
I am charging using 10w Apple wall charger, I can’t find a definitive answer on what to do with supplied cable 😂😂😂😂
Virtually any plug compatible 5v USB charger will work.
The current needed to charge the watch is relatively small [typically < 300 ma] and as long as the USB adapter meets USB standards it will work.
