06-25-2021
04:51
14:09
LizzyFitbit
06-25-2021
04:51
14:09
LizzyFitbit
Sense is barely 2 months old & it won’t charge. Magnet “locks” but won’t charge. Wiped both connection faces (on watch & charger) with a dry cloth, but will not charge. Tried several different working outlets in my home.
05:44
08:26
06-25-2021
05:44
08:26
This a known issue with the magnetic chargers.
Check all 4 pins are equally prominent, if not contact Fitbit support for a replacement under warranty.
Best AnswerHi, @KimR19064 , welcome to the community, I struggled with a similar problem recently when I got a warning about "slow charging" on USB sockets I knew to be good. I cleaned the back of my Sense with warm soapy water and used cotton buds with a twisting motion to ensure the 4 "pits" on the back of the Sense were clean to allow the pins on the charging cable to contact the "pits" properly. This seems to have solved the problem.
Cheers
Gr4ndp4 | UK
