09-20-2021
22:58
17:17
LizzyFitbit
09-20-2021
22:58
17:17
LizzyFitbit
Hi,
Not sure if you guys frequently encountered "Clock Error" with the Clock Face?
See the image for the error Clock Error
Have to go to the App and re-select the Clock Face to go back to normal.
09-21-2021
15:51
03:25
09-21-2021
15:51
03:25
Hi @KeithLi.. Welcome on board.
Thanks for your efforts and the picture provided. While this is odd, may I know if this happens when doing something on your Sense? Or does it happen by itself? Also, do you recall since when this started to happen?
In the meantime, let's try the following steps to reconnect your watch:
09-22-2021 00:05
09-22-2021 00:05
09-23-2021 18:46
09-23-2021 18:46
@KeithLi. It's good to see you again.
Thanks for getting back with the requested information, and for your willingness to try the steps suggested above. If by any chance the issue persists, please reply back with the model of your phone and the OS version. These details will help me to investigate on my end and help you out with this matter.
See you around.
10-04-2021 21:06
10-04-2021 21:06
Hi Lizzy,
I am using Oppo Find X 3 Pro running on Android 11.
The firmware of the Fitbit Sense is 44.128.5.49.
The problem still remain and the firmware seems buggy.
Today the Sense display a cartoonish clock face which I never download or install before.
See attached image. Error Random Close Face
10-07-2021
15:25
09:16
10-07-2021
15:25
09:16
Hi there, @KeithLi..
Thanks for the details and the pictures provided. Because your phone meets the requirements, it's fully compatible with the Fitbit app. However, it's odd that your Sense shows an undefined message instead of your step count. I'm sorry for this inconvenience and to work on this matter, please give a try to the following:
