09-09-2022 01:04
09-09-2022 01:04
When my sense is fully charged, the battery with the line through it still comes down into view for a second. The battery symbol on the clock face shows the correct battery life. Why won't it go away?
Best Answer09-09-2022 02:45
09-09-2022 02:45
Hi, @Rhythmman, welcome to the community, check out page 21 of the user manual to ensure you have correctly identified the indicator.
How do I charge my Fitbit device? provides advice and information on charging. If you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
Best Answer09-09-2022 05:35
09-09-2022 05:35
Hi @Rhythmman - does this also happen when the watch is synced to the Fitbit App, so that it shows 100%?
Best Answer09-10-2022 17:52
09-10-2022 17:52
@Rhythmman The critical low battery is red. If you are seeing a white icon with a slash, then you lost your Bluetooth connection with your phone.
09-10-2022
22:14
06:04
09-10-2022
22:14
06:04
Hi @Rhythmman - as @NanaRuns says.
The correct place to see your status indicators is How do I navigate my Fitbit device?
Look for Sense and understand status indicators section.
