12-27-2021 05:53
12-27-2021 05:53
I just got my Sense for Christmas, so last night was the first night wearing it to bed. It did not record any sleep data.
12-27-2021 06:00
12-27-2021 06:00
Hi, @SunsetRunner, welcome to the community, may I draw your attention to this article How do I track my sleep with my Fitbit device? you will see you need to be sleeping for at least 3 hours. Once you've had a chance to go over this article and looked for a sleep score over a couple of nights please post here again if you are still stuck.
Cheers
Gr4ndp4 | UK
Best Answer12-28-2021 06:02
12-28-2021 06:02
I looked at the link you sent. It says when you’re totally at rest, the Fitbit will start recording sleep in about an hour. It did record last night’s sleep, but started about 3 hours after I went to bed. Waiting an hour isn’t too bad, but not recording until after 3 hours pretty much makes it useless as far as a sleep score goes.
Best Answer12-28-2021 06:19
12-28-2021 06:19
Get used to that. I have had a Sense for 6 months and only get a “sleep score” once a week or so. I’ve been on with support so often I expected to see them at Christmas. It just doesn’t seem to work. Versa seemed to be better. Sadly I can’t afford to make a change, I strongly suggest you just accept that it’s not going to work. They actually replaced my original unit, without any improvement.
12-28-2021 06:22
12-28-2021 06:22
I’ve don’t all this. I sleep between 5 and 7 hours a night, wear it snugly but not tight on my non dominant hand, do everything they told me to do. It doesn’t work. Period. This is my second unit— they replaced the first for the same reason. The upside is I’ll let the premium expire.
12-28-2021 06:23
12-28-2021 06:23
Useless Is an excellent description. (Can you tell how frustrated I am about this?😂😂)
Best Answer12-28-2021 06:25
12-28-2021 06:25
Sorry— can’t edit. Should say I’ve “done” all this
Best Answer12-28-2021 12:42
12-28-2021 12:42
I used a Charge 2 for a few years. It kept track of my sleep. My husband bought me the Sense for Christmas. You’d think it would work as good as an old version!
12-28-2021 12:55
12-28-2021 12:55
