12-28-2021 08:47
12-28-2021 08:47
Hello.
I just received a Sense Fitbit. Set it up right away -- Everything seemed to be set up properly and working as it should. Notifications were being received on the watch as expected. But within a day, the notifications just stopped.
After reading through many related topics on this forum and trying multiple fixes, this worked the best. Problem fixed...I thought.
Notifications were back and all looked good.....for one day. By the next morning, all notifications stopped again. The above technique has me up and running again, however, I fear that it will be short lived. Plus, I shouldn't have to go through the above daily. Any suggestions? Why are the notifications working one moment and not the next? No settings are being altered in between. Help! Thanks.
Best Answer12-28-2021 09:56
12-28-2021 09:56
Have you rebooted the sense at all?
That’s the first thing I’d try. Maybe it will help
with the continuity of notifications
Also. what phone are you using?
Best Answer12-28-2021 12:29
12-28-2021 12:29
I had the same problem and frustration until I realized I was inadvertently turning on the Do Not Disturb when I swiped around trying to learn how to use the device. No problem since.
12-28-2021 13:43
12-28-2021 13:43
Thanks!! I have an iPhone 8. I tried to reboot the sense the first time around....it didn't help.
Best Answer12-28-2021 13:49
12-28-2021 13:49
Did you check to make sure you don’t have Do Not Disturb turned on on the Sense? Swipe right from the clock face. It looks like a circle with a minus sign in the middle.
Best Answer12-28-2021 14:09
12-28-2021 14:09
I did. So far, that hasn't been the issue. I will keep an eye on it though. Thank you for your help!
Best Answer12-28-2021 15:36 - edited 12-28-2021 15:42
By an off chance is the focus mode on your iPhone
turned on?
Swipe down the top right corner of your phone.
you’ll see a moon within a circle. If that is on or
on a schedule to go on, it will stop the Fitbit sense from notifications going through.
I still get texts on my phone but not on Fitbit when it is enabled.
Also if your referring only to text notifications, you can’t have the sms open on the phone screen and receive a text on your Fitbit. Swipe up the sms screen.
I guess Fitbit feels if you got the sms screen open then why would you need a notification? You’ll see the text pop up in front of you.
