Sense disconnects daily from phone
My Sense disconnects from my Android phone every night.      I have to set Sense up as a new device every day.     Sometimes that takes up to 20-30 minutes.     My phone is a Moto E4 Plus with 2 GB ram.   Could it be that my phone can't handle Sense?
1 REPLY 1
@Lawofthewest Thanks for stopping by!
Let me help you with your Fitbit Sense disconnecting from your phone. I don't believe that your phone can't handle your device but I would like to know if it has enough internal memory? This could affect the Fitbit app from properly working and cause syncing issues. Still I suggest you refresh the link between your phone and your Sense by doing the following:
  1. Go to your phone's bluetooth settings and remove all devices listed there.
  2. Restart your phone and restart your device
  3. Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  4. Also, on an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  5. You can find troubleshooting instructions here.
Let me know how it goes.
Alvaro | Community Moderator
