06-24-2021
21:34
15:24
LizzyFitbit
06-24-2021
21:34
15:24
LizzyFitbit
Ive been a long time user of Fitbits, but noticed that my last two have sucked. Of course, I got the "best" models, the current being the Sense, and the previous being the Ionic-Adidas edition. Both have stopped working shortly after getting them! The current Sense doesn't charge and I got it 4/6/2021...COME ON! This is unacceptable. The Sense's total cost with the warranty was $383.17 and it cant even last 6 months??!! I wouldn't be as upset about it if this was the first time, but now this is two in a row with the Ionic costing over $250 a few years back.
For the amount of money Ive spent trying to use these watches, I think it's worth it just to switch to a Garmin or anything else that will WORK.
Sooooo annoying!!!
Moderator Edit: Clarified subject and formatting
Best Answer06-24-2021 22:14 - edited 06-24-2021 22:14
There is a known issue with the chargers - Check the 4 pins are equally prominent, if not it needs replacing.
Probably best to contact Fitbit Support directly. They may be able to help you with a replacement charger.
Best Answer06-25-2021 06:04
06-25-2021 06:04
Hi, @MVPs05 , welcome to the community, I struggled with a similar problem recently when I got a warning about "slow charging" on USB sockets I knew to be good. I cleaned the back of my Sense with warm soapy water and used cotton buds with a twisting motion to ensure the 4 "pits" on the back of the Sense were clean to allow the pins on the charging cable to contact the "pits" properly. This seems to have solved the problem.
Cheers
Gr4ndp4 | UK
Best Answer06-25-2021 07:57
06-25-2021 07:57
Thank you, they are all prominent and it still isn't working 😔
Best Answer06-25-2021 10:03
06-25-2021 10:03
Hi, @MVPs05, thanks for your info, I'm concerned I may not have expressed myself clearly, I refer to the little dimples in the back of the Sense, not the pins in the charging cradle.
Cheers
Gr4ndp4 | UK
Best Answer06-25-2021 10:05
06-25-2021 10:05
Hi Gr4ndp4,
I tried cleaning the dimples this morning and that didn't work either unfortunately. I just need to send it back at this point. Thank you for taking the time to help me!
Best Answer06-25-2021 10:11
