07-01-2022 15:35
07-01-2022 15:35
Hi, I am wondering if the sense is durable, I am asking this because I do a lot of contact sports, and I am generally clumsy, so I need a durable Watch, please tell me if it is durable.
Best Answer07-01-2022 16:27
07-01-2022 16:27
Hi @ShadowNinj,
I've had mine since release day and I've worn it the entire time. During that time it's been crushed into door jams, dropped, etc. and there's not even a scratch on it.
one cruise ship at a time!07-01-2022 17:07
07-01-2022 17:07
Would suggest fitting a tempered glass screen protector before first wear. Try to protect the device as much as possible. It's NOT bullet proof, as many have found out. Avoid banging the screen - even with a protector on.
Personally I'd be reticent to wear a Sense playing contact sport. YMMV though.
07-02-2022 08:10
07-02-2022 08:10
Will adding a screen protector disable the EDA scan since the EDA scan works by touching the screen?
Best Answer07-02-2022 15:40
07-02-2022 15:40
EDA works fine.
Best Answer07-02-2022 21:21
07-02-2022 21:21
Can you please recommend a screen protector?
i really need one then since the EDA scan works with a screen protector.
Best Answer07-02-2022 23:47 - edited 07-02-2022 23:50
"Can you please recommend a screen protector?"
I can, but unfortunately my eBay history for the protectors has gone. Even though I only purchased 4th March.
I'm assuming you're not located in Australia?
But I'm sure you can source similar items from where you are.
Here is a link for similar protectors to the 3 pack I purchased. I purchased ones with the black border around the protector which looks really good and doesn't cover any of the display (in case you were wondering).
fitbit sense tempered glass screen protector: Search Result | eBay
