09-16-2021
19:18
04:11
09-16-2021
19:18
04:11
I have tried various recommendations, including pressing and holding side button. It just seems to be stuck in this perpetual sequence (logo--dark screen). I have also resorted to letting the device drain its power-- thinking it would reset and be solved (to no avail). Please help.
09-17-2021 05:09
09-17-2021 05:09
@georgelungu Welcome on board. I'm sorry to hear you and your wife are having this issue. Thanks for trying to fix the inconvenience already.
If you haven't done so yet, I'd suggest following the steps below:
If you can't get started with your Sense, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Best Answer09-17-2021 04:16
09-17-2021 04:16
Hi there, @aeh12345. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Sense before reaching out.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer09-17-2021 05:04
09-17-2021 05:04
I have the same issue with my wife watch. I try different methods but stil not working.
09-17-2021 05:09
09-17-2021 05:09
Hope that helps.
Best Answer09-07-2022 08:12
09-07-2022 08:12
Im running an Android phone and the Fitbit App is a LEACH! It refuses to stop, it automatically restarts when the phone starts. the ONLY way to kill it is to uninstall it.
The app is unreliable connecting, transfering and IF it does it is SLOW, Sync is SO SLOW!
Once it connects well it runs fine but it is horrible.
Granted it could be that Fitbit and Android is a bad fit. I run a Motorolla Power.
I have had more problems with the Sense than I think it is worth.
It loses Bluetooth often.
Is inconsistent with the phone app.
It work exteremely reliabably with connection to Text etc and I am impressed with the way this feature works.
HR works as expected
O2 Senser seems flakey I mean you have to wear it for a long time before it figures out if it is accurate
I am not so sure I will keep it. If they will allow me to I will return it.
