I've done all the resets, cleared the cache, unpaired, reset, turn off phone, Uninstaller the app, reinstall, add new, replace device, etc. No we are back to reset failed data was not cleared. It also seems my screen doesn't work when touched. What is a new suggestion to test?
Hi @Davidkp - did you try this sequence
Basically a clean state install of the watch.
Best AnswerYes I did it again as you said and I'm still getting the reset failure. It will actually give me a 4 digit code, pair and then upon reboot give me the error again and again. It still seems to keep track of my steps and heart rate, but the screen doesn't work at all and I have the error.
