01-22-2021
05:41
06:52
WilsonFitbit
01-22-2021
05:41
06:52
WilsonFitbit
This morning my Sense recorded a 7:41 wake up time when I woke an hour earlier. It did log moderate activity at 7:11! Anyone else with this error and how do I fix it?
Thank you
It is easy to change either the start or end time for recorded sleep activity, @Irish57. In the app select the desired sleep recording to open it, then select the Edit Pencil at the top of the screen to open the recorded times. You can change the time to your desired numbers, and the select OK, Save, to save the changes.
@Irish57 wrote:
Thank you so much! Hopefully it won’t happen again which would indicate a problem with my new Sense!
It is not necessarily a problem with your Sense. Other trackers periodically get it wrong, too. I frequently get a sleep pattern reported for a time that I am watching a movie, and my arm isn't moving enough for the tracker to think I'm still awake. Fortunately, such entries are easily deleted.
Hello @Irish57 Welcome to the Community Forums! @USAF-Larry It's great to see you around and thank you for your input!
I was able to see that @USAF-Larry provided assistance about your inquiry. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Have a great day!
Best AnswerPerfect, it has not acted up again so that is a great thing. Folks have been so very helpful. I have a few more questions as I transition from my Versa 2 to the Sense. Missing some of the features on Versa 2. Not sure if it is me not finding them or the difference in the watch.
@Irish57 I am glad to know that the difficulty is now resolved!
Regarding your inquiry, I would like to share with you the manual of your Sense so you can learn more about it and the difference between this device and the Versa 2.
You can find the manual here. You can also check How do I get started with Fitbit Sense?
Keep me posted.
@Irish57 Thank you for reading the manual and the link shared!
If possible, it would be great if you can list the features you're inquiring about. This way I can provide information and look for the appropriate reply to your questions.
I look forward to your reply.
