04-21-2023
08:02
11:35
ManuFitbit
04-21-2023
08:02
11:35
ManuFitbit
Has anyone else seen a marked increase in their Fitbit Sense battery usage?
A battery for me use to be able to last 4 or 5 days - I would refrain for charging it when I was washing, just to see how long it would last.
In the last 2 weeks though, there has been a sharp drop to the point where it will blitz through the battery within 2. Its almost like flicking a switch, or a battery hungry update was pushed.
I have not changed anything, my sleeping habits are not different, even reducing the screen timeout to 8 seconds (it's already on dim and no movement based wake).
It's not even a year old yet, as I only paid the Premium after 6 months trial earlier this year!
Moderator edit: clarified subject.
Best Answer04-21-2023 10:15
04-21-2023 10:15
I most definitely have seen a drop in my battery consumption. Of course, Google doesn't care about Fitbit's user base. They are more focused on their battery hungry pixel watch. Good 🤞 luck!
Best Answer04-21-2023 13:41
04-21-2023 13:41
Check to see if snore and noise detect report was
activated, It uses a lot overnight
04-23-2023 04:33
04-23-2023 04:33
Also check that SpO2 is disabled.
All three are battery hogs and it is possible that one of them accidentally got turned on
