09-07-2021
20:13
04:04
AndreaFitbit
09-07-2021
20:13
04:04
AndreaFitbit
sense not able to charge
Best Answer09-08-2021 02:03
09-08-2021 02:03
This is generally a faulty charge cable issue, check the 4 pins are equally prominent, and gently try the spring pressure of each pin with the back of your nail.
This assumes that the watch is clean and the 4 connections holes have nothing in them.
If the charger is faulty probably best to contact Fitbit Support directly to request a replacement under warranty.
04:11
16:14
09-08-2021
04:11
16:14
Welcome to the Fitbit Community, @Notai. I'm sorry to hear your Sense is not able to charge.
Please follow instructions of help article: Why isn't my Fitbit device's battery charging? and instructions @Guy_ shared with you.
Keep on visiting the forums.
