11-23-2020
18:15
18:23
LizzyFitbit
11-23-2020
18:15
18:23
LizzyFitbit
My ECG has disappeared. I used it two days ago and now it is no where to be found on my sense? Any clue as to what may have happened? I have even tried to re-install it and can not find that either
Moderator Edit: Clarified subject and updated label
Is the app missing from the app store in the Fitbit mobile app? If yes, can you verify that your location in your Fitbit profile is set to the country in which ecg was approved? Finally, have you received the newest firmware update?
I can not find on my watch or in the app store. I'm in the United States. The watch updated yesterday. I used the ECG app either Saturday or Sunday.
18:31
18:16
AndreaFitbit
11-23-2020
18:31
18:16
AndreaFitbit
Firmware version 44.128.4.15
Wait I may have found it. Looks like the app needed updating.....yes I'm an idiot. Thanks
Best AnswerI'm having the same issue.. Every time the ECG needs update, it just disappears from the watch..
Does anyone know how to fix it?
Is there a way to make ECG updates automatic?
Thanks for the help! 🙂
