05-04-2022
08:05
18:54
LizzyFitbit
05-04-2022
08:05
18:54
LizzyFitbit
I cannot get a sleep score on my Sense, which I obtained from Fitbit with an upgrade discount, after I could not get a sleep score on my new Charge 5. I have tried all the known remedies of setting to Sensitive, loosening and tightening the wristband, wearing it higher on my arm, etc. I am also not getting Breathing rate or Heart rate variability on the Health Metrics, assume it is a result of not obtaining a Sleep score but not sure. It is tracking my heart rate throughout the day and in workouts. However, still no sleep score. I lent it to my daughter and she got a sleep score. Is there some other reason, such as medications, or body type that would prevent it from getting a score? I am of low body mass so its not like my arm is fat, only weigh 150 lbs. Seems odd that I could not get a Sleep score on the Charge 5 and now on the Sense. Any thoughts or answers?
05-07-2022 15:15
05-07-2022 15:15
I have the same problem and have tried the same fixes but with exactly the same result - no sleep analytics, sleep score, HRV etc etc. My heart rate, skin temperature and SpO2 are measured throughout sleep with no problem and sleep time is recorded OK.
I have had the same issue with the Alta HR, Ionic and now Sense.
Is there some issue with the Fitbit algorithm and an HRV cut off?
05-08-2022 04:41
05-08-2022 04:41
They cannot seem to fix it, I spoke to many Customer Service Reps. and eventually was told that it was escalated to a higher level. I waited and never heard back. I finally called and they offered a replacement of the Charge 5 or a great discount on the Verse. I took the option of the Verse and still have the problem. No idea what the issue is, hopefully maybe someone will look at our Dashboards and try to figure it out for the reputation of the company.
Best Answer05-08-2022 05:10
05-08-2022 05:10
Best Answer05-08-2022 05:13
05-08-2022 05:13
I have downloaded a clock face that shows HRV (search: eHeart) to see if it sheds any further light on the situation. Is it a problem with placement of Fitbit on wrist or a problem with the sensor or a problem with measurement interpretation by the software? If I get no joy I will probably cancel my Premium subscription.
05-08-2022 05:23
05-08-2022 05:23
Are you getting the Sleep score now with the new clock face? Also, exactly where did you find the clock face? I don't know what eHeart is, I am 72 and not familiar with a lot of this techie stuff.
Best Answer05-08-2022 06:28
05-08-2022 06:28
I haven't been to sleep yet so I may find out tomorrow! You should be able to search the clock face in the Fitbit App.
PS I'm not much younger than you...
Best Answer05-08-2022 06:54
05-08-2022 06:54
Best Answer05-09-2022 06:52
05-09-2022 06:52
I downloaded the eHeart clock face on my Sense. It worked well and gave me readings for SDRR, RMSSD and pNN50 that were in line with what I would expect for someone of my age. (You can get more details on the measurement definitions in a Fitbit sponsored article in the medical journal The Lancet).
I wore the Sense overnight and checked my eHeart readings upon waking. They were measuring OK. Then I checked for a Fitbit Sleep Score. There was none, only an overall sleep time.
This sleep score problem is getting irritating.
Best Answer05-09-2022 08:32
05-09-2022 08:32
Best Answer05-09-2022 09:22
05-09-2022 09:22
Best Answer05-09-2022 10:23
05-09-2022 10:23
05-29-2022 04:48
05-29-2022 04:48
Just following up, still no sleep score. How about you?
Best Answer05-29-2022 05:11
05-29-2022 05:11
I got a sleep score Monday and Tuesday last week and I got one this morning.
I spent some time on the phone with support and did a factory reset on Friday. Still no Oxygen saturation and no Heart rate variability.
Using a month old Sense.
Best Answer05-29-2022 05:21 - edited 05-29-2022 05:23
I have never gotten a Sleep Score, Breathing rate or hear rate variability. Last two days have not gotten a readiness score, which I had been getting. Restarted today, but do not want to do a factory reset at this time. I had the same problem with the Charge 5. I am starting to believe it may be certain medication that I am on but not sure.
Best Answer05-29-2022 05:27
05-29-2022 05:27
Still no sleep score. Will try a factory reset on my Sense.
Best Answer05-29-2022 05:36
05-29-2022 05:36
Thanks David, let me know how it goes.
Best Answer05-29-2022 06:56
05-29-2022 06:56
If you sync the fitbit before a factory reset you will not loose your data. I would recommend that if you decide to do a factory reset be on the phone with support and make sure you have wifi setup, I had a couple of problems that support got me past very quickly. A factory reset using Bluetooth will take about and hour possibly a bit less, on WiFi it takes a few minutes.
05-29-2022 07:28
05-29-2022 07:28
Thanks for the info Rainwind!!!
Best Answer05-30-2022 15:21
05-30-2022 15:21
Your welcome.
Rainwind
