08-10-2024
16:21
17:31
CrisVillaFitbit
08-10-2024
16:21
17:31
CrisVillaFitbit
Sense is tracking steps but not distance…when will this be fixed?
Moderator edit: edited title to clarity.
Hello and welcome to the Fitbit Community, @ammieoggie.
Thanks for letting me know about this situation in regards to your Sense tracking distance.
I recommend you to check this 'What are some tips to make sure my Fitbit daily activity is accurate?', I'm positive it will help you improve this situation. Also, I recommend you to restart your Sense, just to make sure everything is ok.
Best AnswerObviously I checked the link and rebooted before posting the issue...this did not improve my situation. Not helpful at all, this response was even more frustrating. ☹️
Any news on a fix from fitbit? It's been a couple of weeks now that the watch won't track distance. I bought my new sense a few months ago, and knowing distance traveled everyday, was one of the reasons. No justification by fitbit whatsoever?
Best AnswerNo, doesn't appear so. My tracker has started behaving the same, and none of the other fixes are working. Even the support has no clue when it'll be fixed.
Hi everybody ! Thank you for your messages and feedback .
Our team is aware of the situation and is working on a solution to it.
Many users have now confirmed that they were able to fix it by entering the stride length themselves. It's worth a try until our team has worked on the solution.
You can find instructions for this here:Can I change my stride length in my Fitbit account?
Please follow this thread where all updates will be posted. Distance appears as 0 after sync
